Hi everyone, sorry if my question has already been answered. I'm completely new to this. I downloaded a watchface to my PC and customized it to my liking using the ZeppOS Watchface Generator, then saved it as a ZIP file. Now I have no idea how to generate a QR code to get the face onto my T-Rex 3 Pro, or if there's another way.
Cheers, Michael from Germany
How do I generate the QR code? [T-Rex 3 Pro]
- GIK-Team
- root
- Has thanked: 1169 times
- Been thanked: 280 times
You can find instructions on how to synchronize your watch face with your watch (ZeppOS) in the provided link: viewtopic.php?p=17161#p17161mbmuch wrote: 03 Mar 2026, 18:34Hi everyone, sorry if my question has already been answered. I'm completely new to this. I downloaded a watchface to my PC and customized it to my liking using the ZeppOS Watchface Generator, then saved it as a ZIP file. Now I have no idea how to generate a QR code to get the face onto my T-Rex 3 Pro, or if there's another way.
I'm lost.
What's wrong?
What can I do?
Cheers
I'm lost.
What's wrong?
What can I do?
Cheers
- GIK-Team
- root
Those errors usually mean the file you’re trying to install isn’t a valid package for your watch (wrong format/model, corrupted zip, or built for a different device/OS).mbmuch wrote: 04 Mar 2026, 06:53Ok, i tested it. But the QR don't work. I got the error message: "Parse mini program package failed" or "send package to device failed".
I'm lost.
What's wrong?
What can I do?
Cheers
To help you properly, please attach a sample of your watch face file directly in that forum topic (the one I linked earlier). Upload the ZIP/ZPK there (or share a download link), and mention your exact watch model. Then we (or other authors) can check if the package is correct and tell you what needs to be fixed.
