How do I generate the QR code? [T-Rex 3 Pro]
mbmuch
Post by mbmuch »
Hi everyone, sorry if my question has already been answered. I'm completely new to this. I downloaded a watchface to my PC and customized it to my liking using the ZeppOS Watchface Generator, then saved it as a ZIP file. Now I have no idea how to generate a QR code to get the face onto my T-Rex 3 Pro, or if there's another way.
Cheers, Michael from Germany
Has thanked: 1162 times
Been thanked: 279 times
mbmuch wrote: 03 Mar 2026, 18:34
You can find instructions on how to synchronize your watch face with your watch (ZeppOS) in the provided link: viewtopic.php?p=17161#p17161
mbmuch
Post by mbmuch »
Cheers Mate :-)
mbmuch
Post by mbmuch »
I'm lost.
What's wrong?
What can I do?
Cheers
mbmuch wrote: 04 Mar 2026, 06:53
I'm lost.
What's wrong?
What can I do?
Cheers
Those errors usually mean the file you’re trying to install isn’t a valid package for your watch (wrong format/model, corrupted zip, or built for a different device/OS).
To help you properly, please attach a sample of your watch face file directly in that forum topic (the one I linked earlier). Upload the ZIP/ZPK there (or share a download link), and mention your exact watch model. Then we (or other authors) can check if the package is correct and tell you what needs to be fixed.
