G-Shock MOD
SleepyHollow
G-Shock MOD
Post by SleepyHollow »
Hello to community. Can someone from the creators help me and convert this watchface for amazfit balance as it is with all the functions and the shortcuts. Thank you and also a thanks to Chacalaca for this lovely watchface.
https://amazfitwatchfaces.com/t-rex/view/16963
Has thanked: 411 times
Been thanked: 2050 times
SleepyHollow wrote: 06 Dec 2025, 04:03
As far as I can see, the watch face you mentioned doesn't need to be converted to
Balance. It can be used directly with Balance.
Because the PNG is encoded the same as Balance and the screen size is the same at 480x480, you should be able to install it via QR code.
SleepyHollow
Thank you, asoo for the information. For some reason I thought the trex 3 had a smaller screen than the balance and that the trex 3 Pro has the same screen.
SleepyHollow wrote: 06 Dec 2025, 05:51
Trex3 , Trex3 Pro 48mm , Balance , Balance2 , Amazfit Cheetah Pro , GTR 3 Pro Display is 480x480
You can found information is this link :
https://docs.zepp.com/docs/reference/re ... vice-list/
