Hi. I'm trying to download watchface HGT 43 by author Jaconix, but Zepp app says error: send package to device failed. When I try to edit WF through the app, it shows me 4 errors in the path.
Can anyone fix this face?
Damaged watchfaces t-rex 3
- Has thanked: 420 times
- Been thanked: 2120 times
The issue is that when you sync a watch face to your watch, the Zepp app reports a "send failed" message because the developer has used unsupported character in name of file , such as those in languages other than English. If these character are present, syncing may cause problems.
issue
I tried syncing and was able to install it.
fixed issue
QR-code for sync :
If you want the edited zip file, download it here.
