Request Watchface
kifrawi
Request Watchface
Post by kifrawi »
Hi All,
Need your help to re-design this watchface for Trex Pro. Thanks.
Has thanked: 415 times
Been thanked: 2075 times
kifrawi wrote: 15 Nov 2025, 01:38
Hi All,
I'd like to recommend you a little advice.
If you want a redesign, you should tell your requirements and how you want it to differ from the original, such as adding or subtracting something.
However, I've already ported this dial.
And judging by your work posted in this web, I suspect you can create your own dial. So, I recommend you try redesigning it yourself to meet your needs.
Honda_TrexPro_packed.bin
(352.47 KiB) Downloaded 62 times
kifrawi
Post by kifrawi »
thanks
