Hi, i'll change my watch hand from javascript, i have try a someone script, but it not works on me.
Is there any a solution to solve this?
How to change watch hand from javascript ?
- Has thanked: 404 times
- Been thanked: 2022 times
First, I recommend posting in the relevant forum.zankezaa wrote: 08 Nov 2025, 14:58Hi, i'll change my watch hand from javascript, i have try a someone script, but it not works on me.
This forum is about watch tools, and I think it's relevant to your question.
For example, if you're talking about the GTR watch face, you should post in the following forum:
viewforum.php?f=38
or you're talking about the BALANCE , ACTIVE watch face, you should post in the following forum:
viewforum.php?f=178
Or, if it's a device other than the example, we recommend searching on the main page:
https://amazfitwatchfaces.com/forum/
and selecting a topic relevant to your question. This will provide you with quick and accurate answers that will be helpful to you.
Also, if you're asking about the script used to create the watch face, please attach the project you worked on and the problem you encountered. This will be helpful in investigating your issue.
