Please convert the watchface for GTR4
Has thanked: 107 times
Hi, would someone please convert this watchface to GTR4?
With gray instead of red please
Thank you
https://amazfitwatchfaces.com/t-rex/view/10012
Been thanked: 2086 times
Wahwah wrote: 06 Oct 2025, 20:43
Thank you
GA-B2100_GTR4.zip
(372.32 KiB) Downloaded 72 times
Gray :
GA-B2100-GRay.zip
(336.34 KiB) Downloaded 71 times
Gray Hybrit :
GA-B2100-GRay_Hybrit.zip
(338.27 KiB) Downloaded 72 times
Change Sunrise / Sunset to Digital Time
Beautiful thank you sir, i was hoping in the request to have lighter gray instead of the red but if it is not possible it is fine as well
Thank you so much i appreciate all your work and time 🙂
Wahwah wrote: 07 Oct 2025, 12:04
Gray :
viewtopic.php?p=21287#p21287
I love it, it is perfect thank you so much 🙂
Hey @asoo sorry to bother you i just noticed the digital clock doesn’t work it is stuck at 18:36, can it be 12 hours digital clock?
Also if you don’t mind can the light gray hours indicator just be dark gray like the rest of the background?
Sorry about that
Wahwah wrote: 07 Oct 2025, 19:24
Hey @asoo sorry to bother you i just noticed the digital clock doesn’t match the analog one can it be 12 hours digital clock?
Also if you don’t mind can the gray hours indicator just be dark gray like the rest of the background?
Sorry about that
If you look closely at the original, you will see that the bottom part does not use Time Digital.
I made same as original.
The bottom part of the original isn't digital time.
But the original is sunrise/sunset.
It seems you didn't attention to what I told you before you downloaded it.
If you need any further modifications, please try to do so yourself.
The dial has already been created for GTR4 and can unpack by using edittor in this web. So, please find a PC and try to do it yourself.
Ok thanks and sorry about that
Parrotlover2001
Post by Parrotlover2001 »
Could you please, please convert this to Active 2?
This is my favorite Mickey Mouse face.
I absolutely love him!
Thank you!
Parrotlover2001 wrote: 14 Oct 2025, 18:15
Thank you!
I'm not sure which watch face you're referring to.
But if you're referring to the one in this thread, I think it should work with the Active2 without convert.
If not, I recommend creating a new thread related to the watch face you mentioned. And you should create your request in the "Active2" area. viewforum.php?f=179
To keep each device organized, make sure the requests are in the correct category.
