[Active 2r] Request to modify - Casio modern
[Please Delete]
Im just new in this community im sorry if I missed some things
- Has thanked: 418 times
- Been thanked: 2099 times
If you want to request convert or request edits to a dial.poatan21 wrote: 09 Aug 2025, 01:40First thank you to the creator and for porting this https://amazfitwatchfaces.com/active/view/1124 I just want to ask how to request to modify this watch face, mainly remove the white and blue outline (causing to make the watch face small) make the text a little big. I got the bip 6 and have this watch face https://amazfitwatchfaces.com/bip/view/43979 and it looks great without the outer line and a bit bigger text.
I recommend first seeking permission from the creator. Before you make take the request edits in the forum. At the very least, let the creator know that you intend to edit or convert their work.
Hi sir thats why I put credit thru this post, I tried to message the original creator however he's not accepting DMsasoo wrote: 09 Aug 2025, 02:09If you want to request convert or request edits to a dial.poatan21 wrote: 09 Aug 2025, 01:40First thank you to the creator and for porting this https://amazfitwatchfaces.com/active/view/1124 I just want to ask how to request to modify this watch face, mainly remove the white and blue outline (causing to make the watch face small) make the text a little big. I got the bip 6 and have this watch face https://amazfitwatchfaces.com/bip/view/43979 and it looks great without the outer line and a bit bigger text.
- GIK-Team
- root
- Has thanked: 1149 times
- Been thanked: 276 times
If you’ve only just sent the message, it’s best to wait a bit — for example, the user @tuman18 was last active on the site on 04.08.2025, so it may take some time before they see and respond.poatan21 wrote: 09 Aug 2025, 02:21Hi sir thats why I put credit thru this post, I tried to message the original creator however he's not accepting DMs
This watchface create by use resource from https://amazfitwatchfaces.com/gtr/view/28913 created on ( 05.11.2022 19:47 ) by @Telecom1 ( Thank for that resource )
