Is Gtr4 New compatible?
Moderatori: asoo, Internal error, Watchmens
vinimtns
Messaggio da vinimtns »
Is gtr 4 New a2040 compatible? Can I use Gtr4 standard watchfaces?
Has thanked: 419 times
Been thanked: 2104 times
Messaggio da asoo »
From the information I can find,
https://in.amazfit.com/products/amazfit ... ew-version
it can be seen that the faces that should fit the "GTR4 new" It should be GTR3pro / Balance / Balance2 / and faces of other devices with a size of 480x480 because according to the information I found, the "GTR4 new" has a screen resolution of 480x480. However, you will have to test it yourself because I am not sure if the image encoding management is the same as the previous devices that use a resolution of 480x480.
The old GTR4 resolution has a size of 466x466, so if installed on the "new GTR4" it probably won't fit on the screen.
Has thanked: 1151 times
Been thanked: 278 times
Messaggio da GIK-Team »
I’d also like to add that we’ve considered creating a separate filter for the GTR 4 “New” (A2040), but there’s a small complication — the manufacturer doesn’t officially list this model as a separate device. In the official Zepp developer documentation (device list here), there’s no specific mention of A2040.
Since we rely strictly on that official list to organize and filter devices on our platform, we’ll wait for confirmation or an update from Zepp before creating a dedicated category for it.
Torna a “AmazFaces app”
