Issues convert fron balance to GTR3 Pro
rush2112
Has thanked: 119 times
Post by rush2112 »
@asoo
watch face balance convert to a GTR3 Pro / noticed that some parts of the watch face are missing. It's been about a month is doing this issue, and now I have to rebuild the watch face from scratch , all your last watch face from balance...maybe the updated from the firmware balance 🤔
Has thanked: 419 times
Been thanked: 2109 times
rush2112 wrote: 08 May 2025, 10:05
@asoo
I'm not sure , which watchface you talk about, but some of the watchfaces I added custom scripts to, if you want to convert them to other devices using the sasha editor, the custom scripts are not included, you have to add them yourself, you can see the scripts I added in the index.js file and add them to the converted watchface by adding them in your index.js file.
I don't think the problem is with the Firmware or Editor Program. As far as I can see, some users have converted my watch face and it works properly.
And I tested the conversion myself and the program works properly. And as mentioned, when converting the watch face, the custom script that I added will not be converted. So I think this is the problem you are talking about.
As for the solution, you have to look in index.js to see what I added and when you have converted the watch face and packed it, then edit your index.js by copying the custom script that I added to my index.js and putting it in your index.js.
rush2112
Post by rush2112 »
Ok, thanks 😊
Users browsing this forum: No registered users and 25 guests
