Hi Guys
so, I'm having a issue with my watchface on T-rex 3. Maybe this questions has already been asked, but I'm not being able to find it...
I used the same image for the Watchface and the AOD background, but strangely, and I can't figure out why, on AOD my watchface takes a green tone and blinks all over.
Any idea on why this is happening?
Thank you in advance for your help.
AOD blinking green light
Bass_guy81
- Has thanked: 1 time
- Has thanked: 420 times
- Been thanked: 2121 times
I think it should be similar to "Balance". You can read more at the link.
viewtopic.php?p=16605#p16605
Bass_guy81
Hi @asoo
Thanks for the reply. It indeed matches my issue, althought the strange part is that my AOD has a black background.
I'll try to tinker with the image I'm using, try to get it right.
Thanks for your help.
