Hello.
Does any one have a dual time zone watchface template that I can use in sasha watchface creator app?
I'm not familiar with programming but find a perfect watchface that has dual time zone feature.
Dual time zone watchface
MSKefayati
- Has thanked: 3 times
- Guydu91
- Has thanked: 58 times
- Been thanked: 10 times
To my knowledge there is a way to create a second time hand by using on the one hand the simple analog clock (hours, minutes, seconds) and by using the pro analog clock with just one time hand (different from the simple version) and with a different angle corresponding to the desired time difference.
Be careful though because it is not configurable after installation on the watch: the offset will always be the same even if you change time zones.
I think there are other solutions for analog clocks but they might be more complex to implement...
A simple solution is to create a touch shortcut to the world clock and select the desired time zones in the Zepp application (this is what I do on my creations).
Best regards.
Guy.
PS : All this with SashaCX75's Watch Face Editor of course...
Best regards.
Guy.
MSKefayati
Thanks for your response. I know that method and yes it's not a good way. I was looking for a correct solution.
