Create Watchface for GTR 3 with switch background
Pox87
Has thanked: 25 times
Post by Pox87 »
Hi guys,
i really like this watchfaces that i saw below:
Do you think is possible to recreate into GTR3 with color coding switch but adding also possibility to change from black and white background ?
Hope is not something too complex.
Thanks in advance if someone wanna try it :)
Pox87
Post by Pox87 »
Hi Guys,
Do you think is feasible or too heavy due to many color switch?
Has thanked: 415 times
Been thanked: 2080 times
Pox87 wrote: 28 Nov 2024, 07:35
Hi Guys,
I'm not sure if it's too heavy for the GTR3, but on the Amazfit Balance it works fine.
GTR3 Version :
( Fixed issue no preview image in selection )
OD_h35_GTR_3V1_01.zip
(2.08 MiB) Downloaded 122 times
Amazfit Balance Varsion :
https://amazfitwatchfaces.com/balance/view/2434
GTR4 Version :
OD_h35_GTR_4.zip
(2.17 MiB) Downloaded 111 times
OD_h35_GTR_4_No_crown.zip
(2.17 MiB) Downloaded 124 times
Has thanked: 107 times
This watchface looks great nice work is it possible to get a version for GTR4 please?
Wahwah wrote: 28 Nov 2024, 13:08
GTR4 :
viewtopic.php?p=19524#p19524
Thank you sir it is beautiful, i just have a question is the crown button suppose to switch the watch background? because it does in the GTR4 version, Is there a way to disable that because each time it turn it switches the background 🙂
Wahwah wrote: 28 Nov 2024, 14:08
Disable tune switche the backgroud with crown :
Perfect thank you 🙏
Pox87
Post by Pox87 »
Hi @asoo is perfect has i had in mind.
Just tested and even the size is quite big in reality work super fast on GTR 3 as well.
Very great job!!!
Thanks a lot :)
