CONVERT WF FOR GTS4MINI
MattiaP123
Post by MattiaP123 »
Hi, are you able to convert this wf for GTS4MINI ?
I'm interested in the Italian version
Thank you so much for your time
https://amazfitwatchfaces.com/gts/view/3163
Has thanked: 436 times
Been thanked: 2137 times
MattiaP123 wrote: 18 Oct 2024, 10:22
There are several Italian versions and you did not specify
So I have converted the version hermes_black_ita_fix2
I did not test it on a real device because I do not have a GTS4mini
All tests were done on the editor only
This dial may have some differences from the original.
Due to different screen sizes, the layout may differ from the original.
Please read carefully
- The faces I have ported, I will not accept any further requests for modification
- If you want to make any further modifications, please do it yourself
This face can be modified using the editor
gts4mini_hermes_black_ita_fix2.zip
(154.38 KiB) Downloaded 103 times
