The ZEPP tool produces at the end a file with the ending ZEP.
It tried to upload it directly, but failed.
Than I tried to reneme the ending into ZIP.
Also failure.
Inside of the ZEP is the following:
-> .ip-package (ca 160KB)
-> default-target-NXP-480x480.zpk (88KB)
-> manifest.json (1KB)[/list]
What need I do to those, that I can upload them?
Kin regards
Manfred2024
How to upload to https://amazfitwatchfaces.com/ faces created with ZEPP Watchfacemaker?
Manfred2024
- Has thanked: 420 times
- Been thanked: 2120 times
The watchface file will be in " .zpk" file ( The file is in zip format, you can use winrar to extract it. )Manfred2024 wrote: 02 Oct 2024, 13:10Spoiler
Also failure.
Kin regards
Manfred2024
The watchface will be named is device.zip
Use this file to upload
( You can rename the file from device.zip to whatever you want.zip)
Manfred2024
Thanks a lot !!!!!!!!!
It worked immediately after I followed your instructions!
Kind regards
Manfred2024
Kind regards
Manfred2024
