Watchface request for gtr3
Hi all, can someone please make this orb analogi face for GTR3 please?
https://www.facer.io/watchface/3njYOqo8 ... del=gears3
- Has thanked: 430 times
- Been thanked: 2132 times
Pyczek wrote: 08 Aug 2024, 05:16Hi all, can someone please make this orb analogi face for GTR3 please?
Change center temp. to max min temp ( Because ZeppOS 1.0 cannot use "center temp" vaule on the circle )
- TRK88PL
- Has thanked: 67 times
- Been thanked: 40 times
Nice, but unfortunately @asoo current temperature isn't displayed at all on top, still on Gtr 3 it's not possible to display temp there? No one found a fix for this? I'm just curious
awesome job on this wf as always!
Thank you very much for reporting the issue.TRK88PL wrote: 08 Aug 2024, 17:07Nice, but unfortunately @asoo current temperature isn't displayed at all on top, still on Gtr 3 it's not possible to display temp there? No one found a fix for this? I'm just curiousawesome job on this wf as always!
Since I haven't used GTR3 for a long time, I forgot that ZeppOS 1.0 can't display center temp in a curved manner. I have fixed it so that it shows max min temp instead. would like to know the center temp, please click on the temp shortcut to go to the weather screen.
viewtopic.php?p=18764#p18764
- Has thanked: 205 times
- Been thanked: 5 times
Very nice work, asoo. Is it possible to add animation like balance version in gtr3? Thank you.
This clock that I made does not use custom script, so if you want to convert the animation version in "balance", you can convert it yourself. The clock only consists of white and gray colors, so after converting,It shouldn't affect the image quality in any way.amazfitfacesafrica wrote: 09 Aug 2024, 04:17Very nice work, asoo. Is it possible to add animation like balance version in gtr3? Thank you.
Or if you are afraid of the image quality degradation after conversion
from balance to GTR3pro, you can replace the Folder "assets"
from "Balance" replace in your .zip GTR3pro
because converting from Balance to GTR3pro only converts some scripts, such as animation.
In the image size section and x,y points remain the same. So you can use the resources in the "assets" folder from balance, replace in GTR3Pro.
