Convert for GTR 4
mrbutthead
Has thanked: 60 times
Convert for GTR 4
Post by mrbutthead »
Hello guys. Help me port these two dials for GTR 4 english version, my knowledge is not enough for such work. The author gives permission.
https://amazfitwatchfaces.com/t-rex/view/14141
https://amazfitwatchfaces.com/t-rex/view/14257
Has thanked: 408 times
Been thanked: 2035 times
mrbutthead wrote: 02 Aug 2024, 08:53
It is recommended to specify the watchface you want.
If you notice, you will see that both links have more than 1 dial list in each link. If you do not specify, the person who wants to help you may not be able to figure out which dial you want.
Since you did not specify the dial you want,
I have selected the dial from the list as I see fit,
and converted it to GTR4 by only editing the image size and x,y,h,w values, not editing the script part. Therefore, the dial should work exactly the same as the original. So if the watchface does not work properly, please ask the owner of the work. I will not make any further changes to the completed work.
If the owner of the work wants it removed, please inform the owner of the post. I will not be responsible for the rights of this screen.
This watchface, I did not test on real devices. I only tested on ZeppPlayer, so please manage the risk of using this watchface at your own.
cbf_dotted_v10_466.zip
(980.54 KiB) Downloaded 81 times
CBF_SCOUT V10_466.ZIP
(527.11 KiB) Downloaded 63 times
mrbutthead
@asoo Thank you, I'm very grateful to you
Users browsing this forum: Baidu [Spider] and 1 guest
