Request for port this beautiful wf
RobertV56
Post by RobertV56 »
Because it is so beautiful :) , someone would like to port it to T-Rex2
for which I would like to thank you very much, of course. ;)
https://www.facer.io/watchface/kr93Q4O5 ... ancsummit2
Been thanked: 2088 times
RobertV56 wrote: 23 Jul 2024, 07:23
Weather icon not same the original version and Weather icon has no animation.
CFW_Aniweather_Pro2_T_Rex_2_FIX2.zip
(1.2 MiB) Downloaded 449 times
Version full analog hands:
CFW_Aniweather_Pro2_T_Rex_2_hand.zip
(1.21 MiB) Downloaded 814 times
RobertV56
Post by RobertV56 »
asoo it turned out beautiful again, for which I am extremely grateful, but there is one thing, could you set the sunset a little more inwards, it now comes slightly over the outer ring just before the 15. ;)
RobertV56 wrote: 23 Jul 2024, 20:18
I'm not sure if this is solved correctly because I'm not using Trex2.
I tested on Balance and found no reported issues.
I've tried to fix this using simultor as a character aligner. which the display may not match the real device (T-Rex2)
You can download fixed version in my old post
viewtopic.php?p=18643#p18643
But if it's still not within the range that you're satisfied with, please make additional corrections yourself.
Because I don't have a T-Rex2, I can't proceed properly.
How to fix:
Open the index.js file in the watchface's file (.zip).
( Use the Notepad or other text editor to edit it.)
search
normal_sun_low_text_img = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
 x: 326,
 y: 200,
 font_array: ["Act_0.png","Act_1.png","Act_2.png","Act_3.png","Act_4.png","Act_5.png","Act_6.png","Act_7.png" ,"Act_8.png","Act_9.png"],
 padding: false,
 h_space: 0,
 invalid_image: 'SS_Dot.png',
 dot_image: 'SS_Dot.png',
 align_h: hmUI.align.LEFT,
 type: hmUI.data_type.SUN_SET,
and
idle_sun_low_text_img = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
 x: 326,
 y: 200,
 padding: false,
 h_space: 0,
 show_level: hmUI.show_level.ONLY_AOD,
Then edit the numbers after "x:" to move them to your desired position.
RobertV56
Post by RobertV56 »
You did a perfect sunset asoo, but the city name has now disappeared
RobertV56 wrote: 23 Jul 2024, 21:23
@RobertV56
Please download Fix2 again Fix have some issue
RobertV56
Post by RobertV56 »
It's great now asoo, thank you so much for all your work buddy, and I'm very happy with it too. ;)
RobertV56
Post by RobertV56 »
asoo can you also make it like the link with hands? ;)
RobertV56 wrote: 01 Aug 2024, 07:28
Version full Analog Hands :
RobertV56
Post by RobertV56 »
Thanks asoo, nice work ;)
