BALLOZI INTERO Digital GTR3 Pro
- Has thanked: 205 times
- Been thanked: 5 times
Hello guys to all, can anyone with knowlwdge from skilled creators to port this watchface with ability to change colours and backgrounds like prototype. Thank you.
https://galaxystore.samsung.com/geardet ... ?langCd=el
https://play.google.com/store/apps/deta ... e&hl=en_US
- Has thanked: 430 times
- Been thanked: 2132 times
Understand before downloadingamazfitfacesafrica wrote: 21 Jul 2024, 08:17Spoiler
Steps progress will be activated when you have reached 10% of your steps goal, as the Steps progress display for this watchface uses the reverse image format.
Amazfit Balance Version :
https://amazfitwatchfaces.com/balance/view/1302
GTR4 :
viewtopic.php?p=18635#p18635
Thank you asoo for this lovely watchface!
mrbutthead
- Has thanked: 60 times
@asoo Hi, can I have a version for GTR 4 ? When converting in the editor, this is the effect of the numbers
The problem is caused by rounding fractions while converting images, actually I can't fix it properly. Because I don't have a GTR4, this issue will need to be tested on a real device only.
However, I initially tried to fix it using the simulator, but I'm not sure if the problem will be solved properly. If the problem persists I would have to advise those of you who have a GTR4 to only modify and test it on a real device.
The fix is not difficult, just open the image that is causing the problem. and only remove the excess.
If the one I edited still has problems I will not further action because I can't properly test the post-edit results.
mrbutthead
