Hi i have this problem. I used your app with my amazfit gts3 and I was able to install your watchfaces, now i change watch and with a Amazfit Active I can't install nothing, the app AmazFaces doesn't detect my watch, although the zepp app detects it correctly
What can it be the problem?
I need the watchface Led Panel for my Amazfit Active.. help me!
AmazFaces doesn't detect Amazfit Active
beralios77
- Has thanked: 420 times
- Been thanked: 2120 times
I'm not sure whether AmazFaces is currently compatible with your device or not. I recommend posting a question in the relevant forum.beralios77 wrote: 19 Jul 2024, 08:59Hi i have this problem. I used your app with my amazfit gts3 and I was able to install your watchfaces, now i change watch and with a Amazfit Active I can't install nothing, the app AmazFaces doesn't detect my watch, although the zepp app detects it correctly
viewforum.php?f=23
But what if you want to install with an alternative Recommended to read more in this topic.
