Power Force 200 request for T-Rex2
RobertV56
Post by RobertV56 »
asoo, as mentioned, I would not request any more requests for the time being, but if you are still bored or have nothing to do :D :D ;) this is a challenge to port this to T-Rex 2, I think it is so beautiful and thought I would ask anyway.
https://www.facer.io/watchface/6GoKCCJ5 ... sicsilver2
Has thanked: 405 times
Been thanked: 2028 times
RobertV56 wrote: 28 May 2024, 16:52
This is a personal opinion. When making a request, I recommend not specifying the individual's name. Because if you have already specified If anyone other than the person you specified want to help you They may decide to ignore your request.
For me, if I see it and I'm interested and I have enough time, I'll take action. On the other hand, if the request includes a specific name, I will ignore that request.
T-REX2 :
BA_POWER_FORCE_200_T_Rex_2.zip
(968.55 KiB) Downloaded 110 times
Amazfit Balance :
https://amazfitwatchfaces.com/balance/view/999
RobertV56
Post by RobertV56 »
You are absolutely right about asking one person for a request, that is not appropriate, I will pay attention to it next time.
As for this wf, it looks perfect again with nice adjustments for which I would like to thank you very much. ;)
Has thanked: 205 times
Post by amazfitfacesafrica »
asoo, can you fix lcd white because it isn't like preview. I attach photo to show you. Black screen works fine. Only white has the problem. Thank you.
amazfitfacesafrica wrote: 30 May 2024, 06:20
The problem you reported, I tested it on Trex2 and found no problem.
I'm not sure why GTR3Pro has that problem, because I use the same code to convert. When I have free time, I'll check it out
While current temperature going black when change lcd panel to white the time and date stays white.
amazfitfacesafrica wrote: 30 May 2024, 06:42
In the T-rex2 I posted it can definitely work normally.
As for the GTR3pro, I've found a problem.
The problem lies in the ZeppOS1 part. It cannot read some commands of higher zeppOS scripts, so an error occurs.
Please continue following at forum GTR on the topic you posted.
Because posting in this topic may cause other people to misunderstand that the problem is with files that are open for download (files that are open for download can work normally on T-rex2 ).
