Request for making gif into a simple watchface
DarshWins404
Post by DarshWins404 »
Hey my request is that can you create a Amazfit GTS2 mini with this gif as background, I would like to learn how to create animations and stuff but i was not able to find any resource online. If you could add time(12hr) and battery info somewhere where it does not cover the main elements of gif then that would be very helpful.
Been thanked: 2090 times
DarshWins404 wrote: 11 May 2024, 12:07
I'm not sure if the created watch face can be installed on your watch. Because the watch face created from the gif you want will have a BIN file size of up to 10M.
Which I'm not sure if it can be installed on GTS2mini or not.
Because I don't know the limit of dials that the GTS2mini can accept and work with.
Therefore, if you are unsure I don't recommend installing it. This attached dial
The attached rar file will include resource and .bin in the file.
From the information mentioned above. If anyone wants to use it, please manage the risks that may affect your device yourself. I cannot be held responsible for any damage that may occur to your device.
Please read the message provided carefully before downloading
This file is not watchface , it will include resource for built this watchface and .bin ( watchface) in this file.
So If who want to access the data, please uncompress the RAR file before using.
watchface.rar
(2.41 MiB) Downloaded 24 times
If who want to edit further, you can find the tools here.
DarshWins404
Sadly i cant flash watch face using AmazFaces app, i tried compressing the image size but no success with that the bin file size remains same, is there some other way?
DarshWins404 wrote: 12 May 2024, 09:14
I can't answer. Because I don't have information about GTS2MINI.
Because I don't use this device.
But if possible, you may reduce the number of png images used for make animation.
It might help reduce the "BIN" size of the watch face, but the animation won't be as smooth as the original.
However, I cannot do any testing because I am not using this device.
If you want to test it, you'll have to do it yourself.
DarshWins404
asoo wrote: 12 May 2024, 14:41
thanks i will try
