GTS 4 MINI
MattiaP123
GTS 4 MINI
Post by MattiaP123 »
Hello, are you able to create a watchface similar to this:
/gts/view/8624
for GTS4MINI
If possible, add a red dot for disconnected Bluetooth
Thanks in advance
Has thanked: 404 times
Been thanked: 2022 times
MattiaP123 wrote: 17 Apr 2024, 08:12
/gts/view/8624
for GTS4MINI
Thanks in advance
total_digital_eng_GTR4Mini.zip
(173.39 KiB) Downloaded 38 times
MattiaP123
Hi asoo, I have tested the watchface and it works well.
Would you be so kind as to want to add this watch face for GTS4MINI as well? Nike logo turns red when bluetooth is disconnected.
https://amazfitwatchfaces.com/gts/view/5426
Thank you very much
MattiaP123 wrote: 19 Apr 2024, 10:04
Thank you very much
if you need Open a new request That is not related to the request in the original dial, it is recommended to open a new topic.
and should clearly state that What model do you want to convert?
From the link you provided, there is a list have 4 model to download.
If you don't inform me. It is assumed that those who want to help you will not be able to know your needs.
