Request pacman watchface for GTS 4
Pe86Hpsi
Post by Pe86Hpsi »
Can anyone convert this
https://amazfitwatchfaces.com/gts/view/11685
to GTS4 watchface and tell me how can inport to my GTS4??????
Been thanked: 2090 times
You can do it by yourself by use "Watch face editor for Amazfit watch on ZeppOS"
viewtopic.php?p=17800#p17800
to convert GTS4min to GTS4
you can sync the watchface ( that use zeppOS ) to you GTR4 by use Zepp app in developer mode with QR code
You can read more here.
Pe86Hpsi
Post by Pe86Hpsi »
i have converted GTS 4 mini watchface to GTS 4 after i converted to zpk file and i created qrcode folowing the instructions given on topic and when qrcode created when i m trying to upload to my watch gives me the error "send pacage to device failed"
here is the converted file i created https://files.catbox.moe/43hbsy.zpk
The problem seems to be due to the resource file naming having some files in special characters. As a result, when zipping, there may be problems in syncing.
As a result, I tried editing the name. Problematic files and try packing again.
Then test the sync with QR code and it can work normally.
Pe86Hpsi
Post by Pe86Hpsi »
Thank you sooo much asoo it worked perfect!!!!
