GTS 4 watchface on GTS 4 Mini
SpaceCadet1985
Post by SpaceCadet1985 »
Just a really quick one. Will a face tagged for the GTS 4 work on a GTS 4 Mini?
Has thanked: 406 times
Been thanked: 2031 times
SpaceCadet1985 wrote: 10 Mar 2024, 10:03
If you don't convert, it won't work properly because, if I'm not mistaken, GTS4 and GTS4mini have the following differences:
1. Uneven screen size
2. The encoding of images is not the same. GTS4 uses type1. GTS4mini uses type2.
3. Different ZeppOS version GTS4 2.1 GTS4mini 1.0 In this section, if you use the GTS4 dial that uses certain types of animation, it may result in that animation not working on GTS4mini.
Therefore, if you want to use GTS4 with GTS4mini, you must convert it first.
Recommended to use "Watch face editor for Amazfit watch on ZeppOS"
To convert .
However Because the screen size X, Y is different, after converting, it may be necessary to re-edit the X,Y points to suit the use.
SpaceCadet1985
Thanks! I haven't bought either device yet but this helpful thank you
Users browsing this forum: Google [Bot] and 10 guests
