Hi There,
Sorry if this is easy but how do you create tapable areas for watch faces?
I have heart rate, battery, steps and date - can the Watchface Maker web app do this? I can't see options in Watchface Maker or mention of it in the official docs sorry.
Any help much appreciated. Cheers, Ben
Can Watchface Maker create clickable/tapable areas? [SOLVED]
- Has thanked: 420 times
- Been thanked: 2121 times
In Watchface Maker, there is a section for creating "shortcuts."BenS wrote: 23 Feb 2024, 20:10Hi There,
It's called a "hot zone" but I'm not sure if it works properly. Because I haven't used it for a long time.
If you want to make those shortcuts, you must manually add them with a custom script to the index.js file or use an editor that supports this, for example:
"Watch face editor for Amazfit watch on ZeppOS."
by use element "Botton" to create a shortcut that is not available in Watchface Make
such as calendar , sport list ................. and many more
