New here. Just bought an Active recently and I noticed there are not really a lot of faces.
Is there a way to request one in particular or a way to convert it by myself from other models?
Because I really like the Pip boy from Fallout.
Thank you!
How to convert Watchface [Active]
- Has thanked: 414 times
- Been thanked: 2073 times
You can use the program "Watch face editor for Amazfit watch on ZeppOS" to convert it, but you need to make sure that the screen size is similar or fits together, and the watch face must be in a group that uses ZeppOS.Vegastar wrote: 11 Feb 2024, 23:10Hello,
Thank you!
Thanks! I'll give it a tryasoo wrote: 12 Feb 2024, 00:36You can use the program "Watch face editor for Amazfit watch on ZeppOS" to convert it, but you need to make sure that the screen size is similar or fits together, and the watch face must be in a group that uses ZeppOS.Vegastar wrote: 11 Feb 2024, 23:10Hello,
Thank you!
