Zepp watchface maker problem with Amazfit Bip 5
memi205
Messaggio da memi205 »
Hi !
The Zepp "WatchFace Maker" web application no longer recognizes the Amazfit Bip 5 watch when performing "Export Watch Face Package" or performing "Run on Device".
In both cases, the "WatchFace Maker" web application gives the error: ZAB NOT FOUND
So, the "WatchFace Maker" web application no longer produces a scanning code.
Can someone verify this ?
I'm stuck, I'm no longer able to make a new watchface or modify my existing watchfaces.
Please, help me !
Has thanked: 405 times
Been thanked: 2031 times
Messaggio da asoo »
memi205 ha scritto: 08 gen 2024, 19:08
Hi !
Please, help me !
I've tested and I've encountered the same problem as you.
I suggest you use feedback to raise the issue with him.
https://watchface.zepp.com/feedback
PS. I have also reported the problem via Feedback.
Or if you use Windows
Please try switching to "Watch face editor for Amazfit watch on ZeppOS."
To create a BIP5 watch face
and use
AmazFaces app
viewforum.php?f=23
To sync the watch face Go to your watch face
memi205
Thank you asoo !
Zepp community just solved the problem !!!
I will look at your suggestion to create a watchface for a BIP 5 watch.
Thanks !
Torna a “Watchfaces tools (discussion)”
Visitano il forum: Bing [Bot] e 5 ospiti
