Seeking possible bug feedback (GTR 3 Pro)
smith725
Post by smith725 »
I just uploaded a very simply watch face at https://amazfitwatchfaces.com/gtr/view/36479
On my watch, this shows a rendering bug in the digital display. And if it is a bug, everything I can see suggests it is in the firmware, as the API calls appear to be just fine.
Now - this might be consistent, or it might be just something on my end - maybe an unexpected watch setting?
Once this is available, I am interested in knowing if other GTR 3 Pro owners see the same bug.
(Many more details in the watch description)
Has thanked: 411 times
Been thanked: 2050 times
smith725 wrote: 31 Oct 2023, 00:37
I encountered the same problem as you when Take the sample dial you left for testing.
I've tried to test it and found that if, The "hour" , you use .
" Add leading Zero " the problems you mentioned will go away.
However If you want to use The "hour" without "Add leading Zero"
It will encounter the problem you mentioned and must wait for the next minute to be refreshed in order to display the correct results.
smith725
Post by smith725 »
So - I just went hunting for any existing GTR 3 Pro faces with digital time and NO leading zero.
... these turn out to be incredibly rare. I found one, but I recognize the watch face maker, and I think he may be well beyond these standard calls (very nice, and very sophisticated programming).
I am starting to wonder if many more people have "discovered" this, but just turned on leading zero and left it that way to avoid the difficulty.
Return to “Zepp OS”
