Hello to all. I already take permission from ZduneX25 to ask for help for heart dial. It is not accurate at all for GTR3 Pro model while ZduneX25 says that for GTR3 and GTR 4 works just fine. Only on GTR3 Pro happens this. If someone can help is welcome. Or if someone can help can contact with ZduneX25 and tell to him what can be done. Thank you.
https://amazfitwatchfaces.com/gtr/view/36149
Amazfit Elegant GTR3 Pro
- Has thanked: 205 times
- Been thanked: 5 times
- TRK88PL
- Has thanked: 67 times
- Been thanked: 40 times
Sorry, my mistake. Thank you for mention it.
- Has thanked: 420 times
- Been thanked: 2120 times
From the thread you mentionedamazfitfacesafrica wrote: 20 Oct 2023, 09:53Hello to all. I already take permission from ZduneX25 to ask for help for heart dial. It is not accurate at all for GTR3 Pro model while ZduneX25 says that for GTR3 and GTR 4 works just fine. Only on GTR3 Pro happens this. If someone can help is welcome. Or if someone can help can contact with ZduneX25 and tell to him what can be done. Thank you.
I think the heart rate pointer of GTR3, GTR3 pro should not display the value with the circle correctly because the pointer in GTR3 GTR3 pro, if I remember correctly, will display 6 zones same as "image progress", so it can be seen that the screen In my creation, if the heart rate pointer is used, I will change it to "low , normal , high" . I will not use numbers because it will not display properly. Or if it were to be performed correctly, It must be tested with real device , and adjust accordingly
The dial you mentioned I was unable to examine due to The dial "index" is encoded in BIN format. I cannot read or understand the file. Therefore, I can only explain the observations that may cause the heart rate pointer display to not work properly as mentioned above.
