Manual for WFE (v9.01) where is ?
Finferlo
Post by Finferlo »
Good afternoon !
I can't find a manual for the WFE program (v9.01), in particular I want to learn how to create buttons to change the color of the backgrounds, numbers, or the shape of the hands. I have a GTR3 Pro.
Thank you.
Has thanked: 414 times
Been thanked: 2073 times
Finferlo wrote: 10 Oct 2023, 14:10
Good afternoon !
Thank you.
In editor 9.0.1 there is a funciton button, but to use those functions in the form Tapping the screen and giving it a change Various elements, you must write additional custom scripts yourself. The program does not have this section.
You can see an example custom script from the screen that has those functions. The script is in the index.js file in the dashboard.zip file.
