I can't open the png files in the "assets" folders
arturovivo
Post by arturovivo »
Hi.
After downloading the zip file of a watch face for GTS 4, when I try to open the png's in the "assets" folder I can't open them. The classic windows photo viewer tells me "Cannot open this image because the file appears to be damaged or too large", and the modern photo viewer tells me "It appears that the format of this file is not supported".
Why does this happen?
Thank you.
Been thanked: 2120 times
arturovivo wrote: 24 Sep 2023, 20:19
Hi.
Thank you.
ฺBecause PNG in Folder assets is not normal PNG . it's PNG Format by ( Zepp )
if you want to edit you must to convert to normal PNG and after you edit finish you must to convert to Zepp (PNG) before bring it to use
You can Found Tool for do That is this link :
viewtopic.php?p=15457#p15457
And Editor in this link ( editor can unpack and pack the watchface and after unpack PNG will converted )
arturovivo
Thanks man!
