下载的表盘,为什么解包后不显示表盘预览图?
lgd123456
Post by lgd123456 »
下载的表盘,为什么解包后不显示表盘预览图?我用的是华米表盘编辑器6.5解包。谢谢!
Been thanked: 2088 times
lgd123456 wrote: 04 Jul 2023, 02:47
First of all, it is recommended If you want to get an answer quickly It is recommended to follow the rules of this forum, which is to use English in conversation.
Since you didn't say which watch face to unpack, so
The problem you asked may be caused by these
1. You are using an old editor version, therefore unable to unpack watch faces made from the new editor version, currently at Version 8.0.
2. The watch faces you unpack . The index.js do not use standard syntax of this editor (may use other editors or create from online editors).
3. The watch face you unpack the index.js is encode , it can't read the code in index.js properly , it can't unpack . In this case , if you want . Edit or convert watch faces It is advisable to contact the owner of the dial.
4. The watch face custom script has been added to index.js so the editor cannot unpack the watch face properly. Sometimes it's possible to unpack but the custom script added to index.js is missing from the file.
