How to create T-rex watch faces?
PetyaDev123
- Has thanked: 1 time
Hello, I have an Amazfit T-rex watch, model A1919. I really want to make my own watch faces for it, but I can't find normal instructions on how to do it. If I make one with Zepp's official watch face maker and extract the source.bin file from it, both the amazfaces page and my watch label it as faulty. Third-party watch face makers do not work properly. I can't even find any developer documentation on how to assemble a watch face and what it consists of. I'm a developer, but it's hard without good documentation. Thank you in advance for your help!
- Has thanked: 130 times
- Been thanked: 19 times
I don't think the official watchmaking site is compatible with your watch. Documentation is difficult to come by. You basically need to learn by doing. Or learn by unpacking existing watchfaces for your watch.
I think Facemaker or the AmazFit WatchFace editor for Windows by SashaCX75 are your only options.
When I started, I unpacked an existing dial into SashaCX75's app and noted how it was put together then I figured out how to create my own.
@PetyaDev123 I posted some resources a while ago. They might still be relevant. I would also suggest picking up the apps from the MEGA link I posted further down. It has some helpful tools to convert images and quickly create the typeface graphics for numbers and text.
viewtopic.php?p=14144&hilit=amazfitfontgenerator#p14144
