Please help port watchface for GTR3 Pro
Has thanked: 205 times
Post by amazfitfacesafrica »
Hello guys, can anyone with knowledge port this simply watchface for GTR3 Pro and if it's possible add ability to change colour. Thank you.
Has thanked: 438 times
Been thanked: 2141 times
amazfitfacesafrica wrote: 15 May 2023, 13:39
Full AOD Show only Black & White
GTR3 Pro :
SAMSUNG4_GTR3pro_Cscript_FAOD.zip
(241.66 KiB) Downloaded 217 times
GTR3 :
SAMSUNG4_GTR3_Cscript_FAOD.ZIP
(203.59 KiB) Downloaded 226 times
Image.Image
GTR3 Pro ( Short month ) : ( Fix month not show Please download again )
SAMSUNG4_GTR3pro_short_month_fix.zip
(275.73 KiB) Downloaded 207 times
GTR4 :
Samsung4_GTR4.zip
(535.61 KiB) Downloaded 136 times
Thank you its amazing. Is it possible to make date in one row? I mean 16 MAY 2023. Thank you.
amazfitfacesafrica wrote: 16 May 2023, 01:11
It can be done, but I think it might not be pretty because the image used to create months must be the same size (H,W) and I made month with full name , So in this case the month has few characters There will be a lot of gaps. but if you want You can fix this by replacing the original by overwrite index.js in ZIP file,
with attached file
File "index.js" ( GTR3 Pro) :
index.js
(23.68 KiB) Downloaded 175 times
If the alignment is not to your liking You can manually edit the X,Y points of date_imge in the index.js file with Text Editor ( notepad ... )
Thank you so much for index.js file.
Is it possible to make a index.js with 3 letters month like prototype watchface?
Lattenknaller
Has thanked: 62 times
Been thanked: 167 times
Post by Lattenknaller »
this has nothing to do with index.js. You have to adjust the graphics with an image editor for the months.
Lattenknaller
I have edited the graphics of Asoo once. Looks now like this
samsung4_GTR_3_Pro.zip
(224.09 KiB) Downloaded 203 times
amazfitfacesafrica wrote: 16 May 2023, 09:05
viewtopic.php?p=15669#p15669
Thank you, asoo, it's perfect now. Thank you, Lattenknaller too.
asoo, your version of short month don't show months at all. I attach photo to see.
amazfitfacesafrica wrote: 16 May 2023, 12:12
Please wait i will fix it.
Now Fixed Please download again :
Thank you.
mrbutthead
Has thanked: 60 times
Post by mrbutthead »
@asoo Can you make a version for GTR4? When converting through the editor, color changing does not work. Thank you.
mrbutthead wrote: 25 Apr 2024, 17:54
Click link to Download Page
mrbutthead
@asoo thanks
