Editor Amazfit Band 7
For example: Requesting creation of watch face [Stratos 3]
Max83
Post by Max83 »
Hi, how can modify this?
g170__faod_v2_1_script_ab7-15485-67a4956ffa.zip
(336.31 KiB) Downloaded 375 times
whean I try to open with editor 7.x the function variations do not appear
only this appears to me
Thanks for help me
Has thanked: 421 times
Been thanked: 2128 times
This watchface : https://amazfitwatchfaces.com/amazfit-band/view/35
I'm using "7.1" to build only infrastructure and added custom script . So it can't open with 7.x editing or other version. If you want to modify , You only need to edit script in the file index.js directly ( in the .zip ).
Max83
Post by Max83 »
oook mate. thanks
