Hello. Please port this watchfaces for GTR 3.
https://amazfitwatchfaces.com/t-rex/view/10357
https://amazfitwatchfaces.com/t-rex/view/9002
https://amazfitwatchfaces.com/t-rex/view/9062
Thanks.
Port from T-Rex to GTR 3
mrbutthead
- Has thanked: 60 times
- Been thanked: 5 times
- Has thanked: 417 times
- Been thanked: 2092 times
I see all that link is your watchface
I think you probably have the ability and experience in making watch faces. to a very good extent
I advise you to try to create it yourself programmatically.
Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3)
viewtopic.php?p=15191#p15191
I think if you can make a T-rex face, it shouldn't be difficult for you to make your own GTR3 face.
I hope the guide will help you enjoy creating your own watch face.
mrbutthead
asoo I can do it, but for some reason the distance between the numbers turns out to be larger than in the original and adjusting the indents does not help.
I think the problem might be the size of the image.mrbutthead wrote: 23 Mar 2023, 18:36@asoo I can do it, but for some reason the distance between the numbers turns out to be larger than in the original and adjusting the indents does not help.
If you are converting Trex to GTR3
It is recommended to open Trex's watchfac on the trex editor and convert it to GTR to get 454x454 size which is the size of GTR3.
Then take the images and coordinates obtained from the conversion and use them to create the watch face using the GTR3 editor.
mrbutthead
asoo Thanks for the detailed answer, but I tried to port them from gtr 47. I'll try to make a different font.
