Convert watchface from GTS to GTS 3
beralios77
Post by beralios77 »
Hi guy, i love this watchface https://amazfitwatchfaces.com/gts/view/1104 (Led Panel of xRUSx) but i try to ask him a new version for my GTS3 ...but he no answer..
Please anyone can adapt the watchface - Led Panel - GTS version to my GTS3 ??
Help me
Has thanked: 441 times
Been thanked: 2142 times
beralios77 wrote: 14 Feb 2023, 15:18
Help me
Led-FAODGTS3.zip
(42.34 KiB) Downloaded 108 times
beralios77
You're the best.. can i donate you a little present?
beralios77 wrote: 17 Feb 2023, 15:05
I don't want to accept donations ,
if you would like to donate Please donate to Sashacx75
PayPal: [email protected]
Because if do not have his program this watchface will not happen.
K4rol
Post by K4rol »
hey i have also used this program to convert gts3 to active but color are realy bad - what am i doing wrong?
I'm not sure what program you use to convert.
As far as I test Using the Editor program of Sasha Version 10.3
In converting, as I checked the image files obtained from the convert.
It is likely that there will not be any problems you report.
However All testing is do on the editor only because I did not have "Active" to test with.
Files obtained after converting and pack
Led_Active.zip
(41.59 KiB) Downloaded 94 times
Therefore, if you use the dial, please manage the risk yourself.
