Watch faces on the Redmi Smart Band Pro
itaketapps
Has thanked: 9 times
Post by itaketapps »
Is there an app to create/install watch faces on Redmi Smart Band Pro? I choose to replace the Mi Band 4 and among the last options is the Redmi Smart Band Pro at the price of the old Mi Band 5. Please tell me if it is possible to install third-party dials on the Redmi Smart Band Pro? If yes, which program can be used to create them?
Everything will be Ukraine
Pranav8393
Post by Pranav8393 »
Yeah me too waiting for this
Redmi smart band pro
It even have aod support
Please just needs some sparks
I also have a rooted Android And Jailbroken iPhone
if needs for the process
Pranav8393
Here are some resources and watchface from app
https://drive.google.com/drive/folders/ ... cJ9DCiduWB
Hevipway
Post by Hevipway »
That's so great
already have the tool to create it
Hateeyes
Post by Hateeyes »
Hi which tool did you use?
Hevipway wrote: 11 May 2023, 00:10
That's so great
