I bought a chinese smartwatch and it can download watchfaces from the app. I noticed it uses .bin files like other smartwatches and I was wondering how could I unpack these files?
I wanna try and see if its possible to create custom WF for this watch but first I need to unpack this .bin file, could anyone help me with this?
I added the bin file in question
How to unpack a .bin file?
- Attachments
- 1665455782338.bin
- (110.43 KiB) Downloaded 248 times
- Has thanked: 417 times
- Been thanked: 2092 times
If you don't have the example file you're talking about.
I think those who want to help you Might not be able to answer any questions.
I suggest you attach the file you mentioned.
I Actually Don't Know How Open The.bin Files But I Thought You Might Be Charged The File Format Like RAR Or Zip By An Application In Android Or Pc Then Extract File, You Also Can Change The File Format Manually, For This Way You Erase The bin Until Dot And Most rar Or zip Writing Manually Like This .rar Or .zip
For Extracting This Files You Better Use Pc And Open File.
