Looking for this Omega WF
Maus-2022
Post by Maus-2022 »
i have loose it , and found it no more.
Has thanked: 419 times
Been thanked: 2104 times
On the web I found only the gold version.
https://amazfitwatchfaces.com/gtr/view/10572
Maus-2022
Post by Maus-2022 »
its very similar , but i ssek the blue , thanks a lot
Only Change images color and pack
- If used, please do it at your own risk.
This watchface for GTR47mm :
omega_jbma_Blue_packed_zip.bin
(455.33 KiB) Downloaded 49 times
I'm not sure if the color will be correct as you want.
If not correct, you can Unpack BIN to modify the image to meet your needs.
The program used to create this watchface :
viewtopic.php?p=3789#p3789
