I just got a GTR4 to replace my GTR3 PRO.
I had the "everything" stock watchface modified by asoo (full AOD / AOD with seconds hand).
I'm still running on a mac so I do not have access to SashaCX75's tool.
Can someone convert the attached watchface to GTR4?
Thanks in advance
Request to convert a GTR3 pro watchface to GTR4
- Attachments
NfTbIfkFcKOkTjKcoxtpyJOWvGdaXJBi_FAOD_GTR3pro.zip- (377.03 KiB) Downloaded 44 times
- Has thanked: 417 times
- Been thanked: 2090 times
point to notice in advanceGR33ZY wrote: 08 Oct 2022, 16:49Hi,
Thanks in advance
- This watchface script cannot be opened with the SashaCX75's editor because the script is a zapp-specific format. So in this convert I will use notepad to edit index.js
- I don't have a GTR4 in post-modification testing. So I can only check roughly on my GTR3.
- I can only reduce the image size and correct the coordinates from calculating the difference between GTR3pro and GTR4 (about 97.1%).
It's perfect.
Everything works fine on GTR4.
Thanks again asoo.
Thanks again asoo.
Users browsing this forum: Baidu [Spider] and 1 guest
