- Amministratore
Request for GTS 2 mini
Hello, can anyone please convert this watchface https://amazfitwatchfaces.com/gts/view/9244 ? I tried to convert but I couldn't
- Has thanked: 404 times
- Been thanked: 2022 times
Olavonix ha scritto: 28 set 2022, 21:16Hello, can anyone please convert this watchface https://amazfitwatchfaces.com/gts/view/9244 ? I tried to convert but I couldn't
- Not test on real device , only tested on editor
- I will not sure it can work or not. I just try to make it with this tool
viewtopic.php?p=12537#p12537
- If some element not work I could not fix it .
- If have some issue please do not ask me because i can not test on real device.
note :
thanks for trying but when installing the watchface the time does not appear
Please download againOlavonix ha scritto: 30 set 2022, 23:21thanks for trying but when installing the watchface the time does not appear
I try to fix it , but I am not sure it work or not
viewtopic.php?p=13856#p13856
Sorry , Please try to download my last fix , The last fix I change to use time's script from the watchface that it can load normal , But if not work again , I think i can not do it too.
Good luck
thnaks asoo!!!! the time now worked, but the weather does not appear. Maybe it's a size issue when converting
