I try to make it myself but i fail
FriDLaCk
Post by FriDLaCk »
I am trying to convert my old amazfit bip watchface but i cant recompile json, dont know if its my computer or what but i spend more then 5 hours :(
Anyone could help me and convert this one from BIP to BIP s?
I attach the 110x110 preview image too.
ES_0503.bin
(30.21 KiB) Downloaded 114 times
Has thanked: 437 times
Been thanked: 2141 times
This watchface only convert Bip to Bip-s , not test on real device because I don't have it.
I am not sure it's work or not please try by yourself.
ES_0503_Bip-s.bin
(30.81 KiB) Downloaded 122 times
Note : .json bip can not convert to .json bip-s because not have battery text , if want to convert must be add text battery before.
FriDLaCk
Post by FriDLaCk »
asoo wrote: 25 Sep 2022, 03:00
ES_0503_Bip-s.bin
Thanks so much! there are some errores with the battery (a number is showed but icons dont work), i try to fit it by myself, now i can decompile and compile the watchface! here is my firt attemt.
Battery icons didnt work but removed battery icon and km suffix its now showed but step by step!
Again, thanks so much!
es_0503_Bip-s_v2.bin
(42.6 KiB) Downloaded 111 times
