SanFrancisco GTR2
Has thanked: 205 times
SanFrancisco GTR2
Post by amazfitfacesafrica »
Hi guys, can anyone to help me and convert this watchface exactly the same for GTR2 and add digital and analog seconds or anyone of those if it's not possible. Thanks a lot guys. https://amazfitwatchfaces.com/gtr/view/24441
Has thanked: 438 times
Been thanked: 2142 times
Original watchface is made by dinhlam91
https://amazfitwatchfaces.com/gtr/view/21882
If you get permission from owner for modify , I might do this request.
I send him message for permission. I didn't know this was the original. Now that I saw it, it has a better color. Thank you for the information.
Good morning to users and to creators, it's been over a month since I've asked dinhlam91 for permission in watchface comments and I've sent him a personal message about the specific watchface but there is no response and probably the user is not active for some time. I would very much beg for anyone who can and is willing to convert it at the same colour like dinhlam91 for gtr2 and if he answer and it's negative then delete it. Thanks to creators and sorry for the inconvience.
amazfitfacesafrica wrote: 06 Sep 2022, 08:48
Image Image
Same as Original :
sanfrancisco_2_2_GTR2_packed.bin
(590.82 KiB) Downloaded 99 times
Fix icon clear night :
sanfrancisco_2_2_GTR2_packed2.bin
(595.65 KiB) Downloaded 66 times
note :
Thank you, much appreciated. There are error at weather icons. Instead clear night the watchface shows and say cloudy.
amazfitfacesafrica wrote: 06 Sep 2022, 16:56
Please report this error to the owner of the work.
I'm just converting to GTR2 using all the resources from the original.
asoo wrote: 07 Sep 2022, 00:40
I wii inform owner about weather error but I don't think I will find him because as I said before he has been inactive for quite some time. Good morning and thank you.
amazfitfacesafrica wrote: 07 Sep 2022, 01:34
You did it right to report problem to owner , But the problem that the owner does not answer you. I can't help you too.
I think , you don't need to forward that message to me , Because I could not help you about the "owner not answer" you.
The best well I think you can try to fix by yourself.
In this web have all tool for fix that problem.
I can only recommend you this way.
Good luck
Please do not reply this post message.
If have reply same story.
i will beg to ignore it.
