Convert watchface from GTR3 to GTR2 format
[email protected]
Post by [email protected] »
Is there any app to convert watchface from GTR3 to GTR2?
Been thanked: 2117 times
[email protected] wrote: 04 Jul 2022, 05:26
As far as i know
There is no program to convert GTR3 to GTR2.
If you want to convert, you need to unpack GTR3 and bring the unpack image resource to make GTR2 with the GTR2 editor.
sc5148
Post by sc5148 »
What about the other way round? If I want to convert GTR2 watchface to GTR3?
sc5148 wrote: 13 Jul 2022, 08:08
As far as i know , it same GTR3 to GTR2
There is no program to convert GTR2 to GTR3.
If you want to convert, you need to unpack GTR2 and bring the unpack image resource to make GTR3 with the GTR3 editor.
rush2112
Has thanked: 119 times
Post by rush2112 »
Are you able to make a video how to convert a gtr3 in to a gtr2 or make a App and will purchase 🤔
rush2112 wrote: 18 Aug 2022, 16:43
@asoo
If you can use the Program editor GTR2
You only need to extract the GTR3 file and use that resource to built GTR2 on editor
rush2112
Post by rush2112 »
Hello, witch file your talking about can you show me with the picture please..thanks
rush2112 wrote: 19 Aug 2022, 08:28
@asoo
You can found all images in the folder "Assets" But PNG in that folder is a PNG(GT3) format , so if you want to bring that images to use on your GTR2. You must to convert to normal PNG Format.
Program for convert PNG(GT3) to PNG(normal) to PNG(GT3)
This program made by SashaCX75
Thank SashaCX75 so much
IMAGEtOgt3.ZIP
(11.9 MiB) Downloaded 227 times
You can find more information in forum Watch face tool :
viewforum.php?f=29
How to use this program ( China languageม please use google to translate )
viewtopic.php?p=11230#p11230
rush2112
Post by rush2112 »
tntkhang
Post by tntkhang »
asoo wrote: 20 Aug 2022, 04:34
@asoo
IMAGEtOgt3.ZIP
viewforum.php?f=29
Sorry for the more detailed question I do not understand which is the difference between the normal format and the GT3 format. I also google PNG GT3 format but seem no results at all, so could you please tell me which is the differences between those formats. Thanks.
tntkhang wrote: 30 Mar 2023, 09:15
I don't know about the structure of PNG(GT3) either.
What I understand is that it is an image file that GT3 uses.
So if you use normal PNG images on GT3
You must convert to PNG(GT3).
And if you want to bring the PNG(GT3) image for edit it in a graphic editor. You need to convert the PNG(GT3) to normal PNG first.
That's all I understand.
Program used convert PNG --> PNG(GT3) --> PNG
You can find it in this post.
viewtopic.php?p=13466#p13466
If you want more details about the structure of PNG(GT3), it is recommended to ask the owner of the converter (SashaCX75 ) , I think he can give you the best answer.
https://github.com/SashaCX75/ImageToGTR3
tntkhang
Post by tntkhang »
Thanks so much for your explanation,
But what is GT3 in your sentence mean? What is it stand for?
> "What I understand is that it is an image file that GT3 uses."
tntkhang wrote: 30 Mar 2023, 19:19
Amazfit GT series
GT is the model name of the watch. I don't know what it stands for.
GT3 is the 3rd generation of Amazfit, consisting of GTR3 , GTS3 etc.
So , PNG(GT3) = Converted PNG image for use with Amazfit GT series 3
tntkhang
Post by tntkhang »
So GT3 format means it supports for Amazfit GT 3rd generation only, it does not a standart of PNG that can use global by another application, another place.
Thanks.
tntkhang wrote: 31 Mar 2023, 02:51
Thanks.
That's right, PNG(GT3) doesn't use standard PNG. It's made for Amazfit devices.
But not only GT 3rd. it's use on some GT 4th too,
But GT4 some Device and some new device of Amazfit use image not same PNG(GT3) .
such as Amazfit Band 7 , GTS4 mini use PNG that not same PNG(GT3) ,
but as said I don't understand its structure. But Sasha's convert program can convert it.
link to owner post :
https://4pda.to/forum/index.php?showtop ... y121171820
Mirror Version 2.2 :
ImageToZeppOS_2.2.zip
(11.59 MiB) Downloaded 111 times
I think on your post It's starting to be outoff this topic.
If you want to take more exams Suggest you open a new topic.
To benefit those who are interested in the same subject as you
