• 管理员
The new T Rex 2 [T-Rex 2]
版主: asooWatchmens
版面规则
回复
ward3636
来自: El Paso Texas
联系:
帖子 ward3636 »
How can I get watch faces like the one's for T rex pro, I got the new T Rex 2 and I can't find any watch faces, just the one's on the Zepp app, help my email address is [email protected], anybody can make watch face for the new T Rex 2, let me know, thanks
头像
来自: ͼͽ Thailand ͼͽ
Has thanked: 419 time
Been thanked: 2105 time
帖子 asoo »
I am not sure , but you maybe use "GTR 3 watch face" on your T-rex 2. Because Editor official on web zepp show support device in the editor as follows .
Support Device:Amazfit GTR 3,Amazfit T-Rex 2
But i am not sure it work or not because I do not have T-Rex 2 for test
File example made form Editor official on web zepp for T-Rex 2
SampleT-rex2.zip
(809.74 KiB) 已下载 328 次
Yzord
来自: Amsterdam
联系:
帖子 Yzord »
I also would like to know if the T-rex 2 will be supported, because i have issues with the app and my T-rex 2
dbarber1
来自: Southern US
联系:
帖子 dbarber1 »
There is a way to install custom watch faces on the T-Rex 2. I asked Amazefit on Facebook about people making custom faces for it and their reply back was that they have an open source option in the works but no date on when it will be available and made a post on Reddit to let others know about it. Someone suggested an app to try that has watchfaces for the GTR 3 and has a direct sync option that may work. I chose one of the GTR 3 watch faces and had it direct sync to the watch, and it worked just fine. I just did it this morning, so I have no idea if they're any negative effects, but it seemed to work fine. It also detects the watch as a T-Rex 2 as well, and transfer of the watchface to the watch doesn't take too long at all. It's not a huge amount of watchfaces and as far as I can tell you can't direct sync watch face files, but for now it will work until a better solution is found.
Here is the link to the app that was suggested to me on Reddit, which worked for me
https://play.google.com/store/apps/deta ... fitwatches
Detcom
来自: Ukraine
联系:
帖子 Detcom »
I tried to use amazefitwatches app didn’t helped me. Got a T Rex 2 too
Detcom
来自: Ukraine
联系:
帖子 Detcom »
dbarber1 写了: 29 6月 2022, 21:30
It’s working with GTR 3 faces!
So anyway… can anyone remake a face from T-Rex Pro to a GTR 3? 😅
eagerly
来自: pordenone
联系:
帖子 eagerly »
working! thanks!
回复
回到 “Watchfaces discussion”
在线用户
正浏览此版面之用户: 没有注册用户 和 2 访客
