Two Request for [GTS]
erdogankr06
Post by erdogankr06 »
hello, can you convert the watchfaces of the amazfit gts 3 model in the links I added to the amazfit GTS model? I do not have enough knowledge and skills to do this. I had previously obtained the necessary permissions from the owner of the watch interface. Thank you very much in advance.
Link-1: https://amazfitwatchfaces.com/gts/view/8799
Link-2: https://amazfitwatchfaces.com/gts/view/8816
Required permissions have already been obtained:
Has thanked: 404 times
Been thanked: 2024 times
Image Image
ALL function work same as original , But no have AOD because GTS not support
worldtime_packed_zip.bin
(397.25 KiB) Downloaded 24 times
Sun_analog_packed_zip.bin
(446.98 KiB) Downloaded 20 times
note :
