PROTO watchface GTR2
SleepyHollow
- Has thanked: 30 times
- Been thanked: 2 times
Hi guys, i hope you are well, I would appreciate it very much if someone with his skills could create in orange colour this amazing watchface. If there no 24h indicator please add if it's possible. Thank you. Have a nice day.
- Has thanked: 441 times
SleepyHollow wrote: 26 May 2022, 06:58Hi guys, i hope you are well, I would appreciate it very much if someone with his skills could create in orange colour this amazing watchface. If there no 24h indicator please add if it's possible. Thank you. Have a nice day.
- This watchface use "system font" to show the element around the edge of the circle , The element "system font" maybe have some issue with the composition of "image font" element. but i am not sure what element so if some element not show or show not correct on the real device i can not fix.
- element "Digital Time" in " system font " can show only 24H ( Test on Editor ) so I will make it only 24H
- element "weather temp." use by "system font" and if an element is used by the "system font" then most of it will not work on the element "image font". So I will not create low / high temp. same as watchface original. Because i am not sure it work on real device or not.
note :
SleepyHollow
Thank you, you are genius, everything works like the preview, amazing work, almost perfect.
