GTR2 loose current temperature after while
- alexstam78
- Has thanked: 173 times
I have GTR2 and is about a month the watch loses the current temperature after some time and only if I renew the zep application it comes again. Note that the watch only loses the current temperature and only, the zepp application works in the background without limitation from the battery and the location has permanent access. The area isn't lost and the others informations from weather only the current temperature lost after while. Is anyone has this problem? Any help is appreciated.
- Has thanked: 421 times
- Been thanked: 2129 times
I'm not sure if it's the same problem as me.alexstam78 wrote: 26 Apr 2022, 05:59Spoiler
On my GTR3 sometimes it doesn't show "center temp" either, it shows icon no data instead.
This may be due to the submitted weather data without "center temp".
But it have only the highest and lowest temperature data when the system updates the weather again. and the new data obtained has "center temp", the center temp display will return to normal.
- alexstam78
Yes this is exactly what it does to me, it only loses the current temperature and not all the rest of the information, shows the weather icon with two dashes instead current temperature, I also tried older zepp app that I knew worked well and still does the same thing, it started a month and a half ago when i received the MIUI 13 update in Xiaomi Mi 11i. I suspect this may be the problem.asoo wrote: 26 Apr 2022, 11:03I'm not sure if it's the same problem as me.alexstam78 wrote: 26 Apr 2022, 05:59Spoiler
